Salta al contenuto principale
MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement
Cosa ti serve
  1. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, Battery Connector: passo 3, immagine 1 di 2 MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, Battery Connector: passo 3, immagine 2 di 2
    • As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Be sure to pull the connector horizontally toward the battery, and not straight up from the Air, or you may damage the socket on the logic board.
  4. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: passo 4, immagine 1 di 2 MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: passo 4, immagine 2 di 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement: passo 5, immagine 1 di 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement: passo 6, immagine 1 di 2 MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement: passo 6, immagine 2 di 2
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
Conclusione
Altre 31 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
123 Membri
23.583 Guide realizzate
11Commenti sulla guida
Is it possible to replace 2012 wireless card to newer ac card?
Manoj Biswas - Replica
^I have this same question
delgado1kevin - Replica
Hello I just ordered a early 2013 Wifi/Bluetooth Macbook Air card that I will use to replace my current mid 2012 MacAir wifi/Bluetooth. I will keep everyone posted here. The card should arrive next week.
filipemiranda - Replica
Did the 2013 AC airport card work on your 2012 macbook air?
Fritz Gamboa -
Yes it is. I got mine from WWW.QUICKERTEK.COM and it works perfectly. I can now use my Apple Watch to unlock my Mid 2012 MacBook Air 13"
Colin O'Neal - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 79
Ultimi 30 Giorni: 359
Tutti i Tempi: 28,950
