Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Use this guide to replace a dead AirPort/Bluetooth card to regain Wi-Fi capability.
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  1. Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board. Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Be sure to pull the connector horizontally toward the battery, and not straight up from the Air, or you may damage the socket on the logic board.
  3. Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card. Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  4. Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  5. Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board. To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
Linea Traguardo
Altre 18 persone hanno completato questa guida.
Is there any way to exchange the installed AirPort/Bluetooth Card with a newer one providing W-LAN AC?
Skyynet - Replica
Is tihs card is the same as in to Macbook Air 11 ?
Petar Slavchev - Replica
is it possible to renew on of the two antenna cables, because mine get broken while lifting it
milankoehnke1995 - Replica
Did you ever find the cables for sale anywhere? Thanks.
edwalker263 -
Can I replace this card with a newer one that allows Apple Watch unlock in Sierra?
Aaron - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 125
Tutti i Tempi: 39,049
