Salta al contenuto principale
MacBook Air 13" Late 2020 Battery Replacement
Cosa ti serve
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  1. MacBook Air 13" Late 2020 Battery Replacement, Remove the lower case: passo 2, immagine 1 di 3 MacBook Air 13" Late 2020 Battery Replacement, Remove the lower case: passo 2, immagine 2 di 3 MacBook Air 13" Late 2020 Battery Replacement, Remove the lower case: passo 2, immagine 3 di 3
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  2. MacBook Air 13" Late 2020 Battery Replacement, Disconnect the battery: passo 3, immagine 1 di 3 MacBook Air 13" Late 2020 Battery Replacement, Disconnect the battery: passo 3, immagine 2 di 3 MacBook Air 13" Late 2020 Battery Replacement, Disconnect the battery: passo 3, immagine 3 di 3
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
  3. MacBook Air 13" Late 2020 Battery Replacement, Remove the audio board connector cover: passo 4, immagine 1 di 1
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
  4. MacBook Air 13" Late 2020 Battery Replacement: passo 5, immagine 1 di 1
    • Remove the audio board connector cover.
  5. MacBook Air 13" Late 2020 Battery Replacement, Disconnect the right speaker connector: passo 6, immagine 1 di 3 MacBook Air 13" Late 2020 Battery Replacement, Disconnect the right speaker connector: passo 6, immagine 2 di 3 MacBook Air 13" Late 2020 Battery Replacement, Disconnect the right speaker connector: passo 6, immagine 3 di 3
    • The right speaker will be on your lefthand side when working on the MacBook, as it's laying upside down.
    • Slide the pointed end of a spudger underneath the right speaker cable and pry straight up to disconnect it from the audio board.
  6. MacBook Air 13" Late 2020 Battery Replacement, Remove the right speaker screw: passo 7, immagine 1 di 1
    • Use a T3 Torx driver to remove the 4.2 mm screw securing the right speaker to the case.
  7. MacBook Air 13" Late 2020 Battery Replacement, Remove the speaker's stretch-release adhesive: passo 8, immagine 1 di 2 MacBook Air 13" Late 2020 Battery Replacement, Remove the speaker's stretch-release adhesive: passo 8, immagine 2 di 2
    • Use a pair of tweezers to peel back the black pull tab on the speaker's stretch-release adhesive until you can grip it with your fingers.
  8. MacBook Air 13" Late 2020 Battery Replacement: passo 9, immagine 1 di 2 MacBook Air 13" Late 2020 Battery Replacement: passo 9, immagine 2 di 2
    • Grab the adhesive strip's pull tab and slowly pull the adhesive strip out from underneath the speaker.
    • Keep the angle of the adhesive strip as parallel to the laptop as you can. Try to avoid dragging it across the inside of the case.
    • Pull the adhesive strip until it's freed from under the speaker.
    • If the adhesive strip breaks, use a heated iOpener, a heat gun, or a hair dryer to help remove the adhesive:
    • Apply heat to the speaker to soften the adhesive underneath.
    • Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
    • Remove the right speaker.
    • During reassembly, to ensure the speaker performs as expected, install a strip of replacement adhesive on its underside before placing it back into the case.
  9. MacBook Air 13" Late 2020 Battery Replacement, Disconnect the left speaker connector: passo 11, immagine 1 di 2 MacBook Air 13" Late 2020 Battery Replacement, Disconnect the left speaker connector: passo 11, immagine 2 di 2
    • The left speaker will be on your righthand side when working on the MacBook, as it's laying upside down.
    • Slide the pointed end of a spudger underneath the left speaker cable and pry straight up to disconnect it from the logic board.
  10. MacBook Air 13" Late 2020 Battery Replacement, Remove the left speaker screw: passo 12, immagine 1 di 1
    • Use a T3 Torx driver to remove the 4.2 mm screw securing the left speaker to the case.
  11. MacBook Air 13" Late 2020 Battery Replacement, Remove the speaker's stretch-release adhesive: passo 13, immagine 1 di 2 MacBook Air 13" Late 2020 Battery Replacement, Remove the speaker's stretch-release adhesive: passo 13, immagine 2 di 2
  12. MacBook Air 13" Late 2020 Battery Replacement: passo 14, immagine 1 di 2 MacBook Air 13" Late 2020 Battery Replacement: passo 14, immagine 2 di 2
    • Remove the left speaker.
  13. MacBook Air 13" Late 2020 Battery Replacement, Remove the trackpad cable cover: passo 16, immagine 1 di 1
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
  14. MacBook Air 13" Late 2020 Battery Replacement: passo 17, immagine 1 di 1
    • Remove the trackpad cable cover.
  15. MacBook Air 13" Late 2020 Battery Replacement, Disconnect the trackpad cable: passo 18, immagine 1 di 2 MacBook Air 13" Late 2020 Battery Replacement, Disconnect the trackpad cable: passo 18, immagine 2 di 2
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  16. MacBook Air 13" Late 2020 Battery Replacement: passo 19, immagine 1 di 1
    • Carefully peel the trackpad cable off of the battery.
    • The trackpad cable is secured to the battery with some light adhesive.
  17. MacBook Air 13" Late 2020 Battery Replacement, Remove the battery tray screws: passo 20, immagine 1 di 1
    • Use a T3 Torx driver to remove the two 2.6 mm screws securing the battery tray to the case.
  18. MacBook Air 13" Late 2020 Battery Replacement, Remove the battery tray adhesive strips: passo 21, immagine 1 di 3 MacBook Air 13" Late 2020 Battery Replacement, Remove the battery tray adhesive strips: passo 21, immagine 2 di 3 MacBook Air 13" Late 2020 Battery Replacement, Remove the battery tray adhesive strips: passo 21, immagine 3 di 3
    • The MacBook's battery cells are attached to a metal tray as a complete assembly, which is adhered to the case with a total of six stretch-release adhesive strips.
    • Don't attempt to remove the battery cells from their metal backing tray.
    • On the left side of the MacBook, use a pair of tweezers to peel back the three black pull tabs on the battery's stretch-release adhesive strips until you can grip them with your fingers.
  19. MacBook Air 13" Late 2020 Battery Replacement: passo 22, immagine 1 di 3 MacBook Air 13" Late 2020 Battery Replacement: passo 22, immagine 2 di 3 MacBook Air 13" Late 2020 Battery Replacement: passo 22, immagine 3 di 3
    • Grab an adhesive strip's pull tab and slowly pull it out from underneath the battery.
    • Pull the adhesive strip until it's freed from under the battery.
    • Repeat for the two remaining adhesive strips on the battery's left side.
    • Repeat and remove the three adhesive strips from the right side of the battery.
    • If any of the six adhesive strips broke during removal, you can use a plastic card to finish separating the battery tray from the case.
  20. MacBook Air 13" Late 2020 Battery Replacement, Remove the battery: passo 24, immagine 1 di 1
    • Remove the battery assembly.
    • If you're installing a new battery, follow the calibration procedure:
    • Charge it to 100%, and keep charging it for at least 2 more hours.
    • Unplug and use it normally to drain the battery.
    • When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery.
    • Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Conclusione
Once you've completed your repair, your laptop may not power back on until connected to power.
Altre 23 persone hanno completato questa guida.
Carsten Frauenheim
Membro da: 03/10/20
92.285 Reputazione
337 Guide realizzate
iFixit Membro di iFixit
Community
141 Membri
17.709 Guide realizzate
13 Commenti
You’ve gotta be kidding me…
dotmiracle - Replica
Hard to believe, but true.. this is an improvement from a couple generations ago, when you had to disassemble the entire computer or futz about with isopropyl alcohol and credit cards (or dental floss) to remove swollen but still glued in batteries. If this has you feeling overwhelmed, go look at the 74-step guide for the 2015 15” MacBook Pro Battery Replacement.
GeneralKire - Replica
I concur with that. Made the fix for a Macbook Pro 13" 2014 some times ago and it looks really more difficult and stressing, especially with potentially destructive steps. I felt a bit lucky that it worked fine after that and since then...
Pierre Lagarde -
Ok I have the battery out but where do you buy replacement adhesive strips? Everywhere I look they say they are for iphones or generic lcd repair. I had to take the battery out for other reasons and want to put the same battery back in.
Stephen Szyszkiewicz - Replica
Stephen, the linked adhesive is a generic solution & should work just fine. Apple-specific adhesives are sometimes hard to source. You could also cut and adapt stretch-release adhesive strips to fit. Best of luck on your repair!
Carsten Frauenheim -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 131
Ultimi 7 Giorni: 1,011
Ultimi 30 Giorni: 4,404
Tutti i Tempi: 83,835
