Introduzione
Use this guide to replace the heat sink or the thermal paste.
Be sure to apply a new layer of thermal paste before reinstalling your heat sink.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
Remove the two 4.9 mm T8 Torx screws securing the antenna cable retainer on the left display hinge to the upper case.
Altre 11 persone hanno completato questa guida.
