Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Use this guide to replace the display on a 2018 MacBook Air.
  1. Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
  3. Peel back the tape covering the battery connector enough to reveal the connector underneath.
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board. Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket. Remove the antenna cable bracket.
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  6. Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable. Repeat for the other antenna cable.
    • Insert the point of a spudger under one of the antenna cables close to the connector.
    • Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  7. Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket. Remove the display cable connector bracket.
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  8. Use the flat end of a spudger to pry up the display cable connector. Use the flat end of a spudger to pry up the display cable connector.
    • Use the flat end of a spudger to pry up the display cable connector.
  9. Use a T5 Torx driver to remove the following screws:
    • Use a T5 Torx driver to remove the following screws:
    • Four 7.4 mm screws
    • Two 4.5 mm screws
  10. Lift the antenna bar straight up and out of the case. Take care not to snag the antenna bar on any cables or connectors. You may encounter resistance from the clips in the middle of the antenna bar holding it in the case. You may pull hard without damaging anything as long as you pull straight up, perpendicular to the case. Remove the antenna bar.
    • Lift the antenna bar straight up and out of the case. Take care not to snag the antenna bar on any cables or connectors.
    • You may encounter resistance from the clips in the middle of the antenna bar holding it in the case. You may pull hard without damaging anything as long as you pull straight up, perpendicular to the case.
    • Remove the antenna bar.
  11. Use a T9 Torx driver to remove the six 4.9 mm screws securing the display hinges to the upper case. Use a T9 Torx driver to remove the six 4.9 mm screws securing the display hinges to the upper case.
    • Use a T9 Torx driver to remove the six 4.9 mm screws securing the display hinges to the upper case.
  12. With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible. With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible.
    • With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible.
  13. Lift the MacBook and carefully rotate the display to a 90 degree angle with the upper case. The hinges should not move in relation to the display, and should rotate out of the case slightly. Keeping the display at a 90 degree angle with the case, move the display straight down while holding the case still, so that the hinges slide out the bottom of the case.
    • Lift the MacBook and carefully rotate the display to a 90 degree angle with the upper case.
    • The hinges should not move in relation to the display, and should rotate out of the case slightly.
    • Keeping the display at a 90 degree angle with the case, move the display straight down while holding the case still, so that the hinges slide out the bottom of the case.
Conclusione
Altre 11 persone hanno completato questa guida.
Adam O'Camb
Membro da: 11/04/2015
128.232 Reputazione
378 Guide realizzate
iFixit Membro di iFixit
Community
135 Membri
14.980 Guide realizzate
So…….. Which one of those flexes is the camera flex? It seems you skipped over a lot of the connectors in your guide.
Aksel Barnes - Replica
I would like to know this as well same issue with Camera not detected as other comments.
David Thomas -
Y’all need to give bonus points for putting it all back together again. Those T3 screws in steps 5 and 7 are awful hard to get back into place while holding the brackets in place. Not to mention the replacement display I purchased (from a third party) didn’t have the other two brackets in place, so I had to move those over from the original display as well.
The high res images in this guide are very helpful, and the guide is very well written and straightforward. Thanks.
larwood - Replica
I have replaced the complete screen on my macbook air and followed these repair instructions to the letter, but for some reason the camera is not detected, I have double checked the connectors but still no camera detected when opening any app s like facetime, photo booth etc.
colin - Replica
Thank you. Very clear guide. The antenna bar removal IS a tense moment and and I’d suggest everyone carefully look at all three photos in this stage just to facilitate the display logic board falling through the gap. With this guide, this is at the low end of ‘moderate difficulty’.
Richard Leach - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 97
Ultimi 30 Giorni: 471
Tutti i Tempi: 6,318
