Introduzione
Use this guide to upgrade or replace the solid-state drive in a MacBook Air 11” Mid 2013. This MacBook Air uses a proprietary storage drive connector, and is therefore not compatible with common M.2 drives without the use of an adapter.
Before you perform this repair, if at all possible, back up your existing SSD. Then, either familiarize yourself with internet recovery or create a bootable external drive so you’ll be ready to install macOS onto your new drive and migrate your data to the new SSD.
Finally, we strongly recommend installing macOS 10.13 High Sierra (or a later macOS) before replacing the original SSD from your MacBook Air. Most new SSDs require updated storage drivers not found in versions of macOS prior to High Sierra.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
Lift the free end of the SSD just enough to get a good hold of it.
Pull the drive straight out of its socket and remove it from the logic board.
Which type of SSD used in it…is it PCIe??
Which type of SSD used in MacBook air 11inch..mid 2013 model???PCIe??
Altre 52 persone hanno completato questa guida.
15 Commenti
I wonder if someone can help me - I completed the installation and rebooted from a clone of the original drive on an external USB disk. I tried to clone that back onto the new SSD but that failed and now the new SSD does not appear on the desktop and does not appear in Disk Utility. Its not being recognised when I boot up. Do you have any ideas how I can get it to reappear - I assume the format is lost so is there a way to reformat?
Can i upgrade my ssd drive from 128 to 1TB ?
i want to know too
yes you may. You may choose either OWC or Intel 660P.
OWC: https://eshop.macsales.com/item/OWC/S3DA...
Intel 660P*: https://www.intel.com/content/www/us/en/...
*Intel 660P, you will require a connecter “m.2 ngff to” like this: https://tw.ezbuy.com/product/210654110.h...[EZBUYTW][PLA][CN][P].USC_Full.Product.Feed&gclid=EAIaIQobChMIytii0fbc5gIVkKmWCh3VoQ5jEAQYAyABEgI4mfD_BwE ''
tpesthh -
That guide is technically here but the procedures are functionally identical!
Who is making these assessments of difficulty here?!? I’ve seen some guides that are incredibly involved and require delicate cable rerouting, unseating very fragile logic board connectors, and take over an hour, rated as “easy”, while things like this, that are only 5 steps (and realistically only 4) and require nothing more than unfastening a few screws and popping two large, readily accessible connectors, and can be done even by executives with tiny hands while simultaneously watching videos on Breitbart in under five minutes, are labeled as “moderate”. There is no way the difficulty of this thing can reasonable be called “moderate” unless the only things that qualify as “easy” are “Opening the Lid of Your Mac to Use”, and “How to Type Capital Letters on the MacBook Keyboard”!
Seriously, if the goal of this site is to promote people performing their own repairs, calling trivial procedures like this “moderately difficult” only serves to scare a significant number of otherwise willing and able users off.
Difficulty ratings are spelled out as follows: “Very easy—Does not require opening the device. Easy—Requires minimal disassembly and only basic tools like a Phillips or flat-head screwdriver. Moderate—Requires a fair amount of disassembly. This is a task most people would not perform without instruction. Difficult—Requires significant disassembly and may require specialized tasks like soldering.” Etc. It’s up to the guide author to select the appropriate difficulty level, but they don’t always do it consistently. That’s why this is a wiki—if you see a problem, you can edit it yourself and fix it. However, this particular guide’s difficulty level of “moderate” is appropriate, based on the tools and amount of disassembly required.
Any news on possible 1 GB upgrades? There seems to be one from Transcend, which matches up with my MBA (11”, 6,1) . OWC has been having one for a while, but it seems it has been having some problems, so I’d rather stay away from that.
oooops, meant to say 1TB :-$
Hello, what about a screw locked by glue and too much screwed, the T5 screwdriver is faulty and the screw was now damaged.
what kind of solution may i have to dismount the ssd, please …
RE: SSD not showing up. When you go to disk utility, make sure to click view -> view all drives in the upper left hand corner. It should then appear and can be formatted with your bootable USB.
When you say:
Do the 8mm & 2.5mm dimensions refer to the LENGTH of those screws, or the size of the pentalobe? That is, are there other sizes of pentalobe drivers like there are for hex, phillips and torx? When only one dimension is provided, it is usually the socket/driver size, not the screw length, maybe since the length cannot be seen when the screw is installed.
Can I suggest that you clarify your instructions so folks are confident they are only in need of _one_ pentalobe driver?
Nerdily yours,
Larry (whose iPhone 4S can now get through a day without 6 recharges thanks to ifixit.com ;-)
larryleveen - Replica
The 8mm and 2.5mm are the length of the screws. One pentalobe P5 screwdriver suffices for all the screws (P5 is implicitly the size of the pentalobe screw heads).
Michael Welham -
I sourced all the parts from ifixit, plus a magnetic project mat which I found to be very useful for organising the teardown and reassembly.
Allen - Replica
The magnetic mat is
GERARD SZAREK -
Keep the 2.5mm tiny screws away from the MagSafe connector as they will be attracted and sucked in to the magnet.
Frank O'Carroll - Replica
A tip an old bench tech taught me that has saved me many times: I put clear “Scotch” tape over the case screws as they became “free”. The tape kept them in place while I lifted the lid off, cleaned it etc.
Michael Mee - Replica
Thank you for a really smart tip! I will be using that countless more times!
Lilljedahl -
I’m confused about internet recovery and installing MacOS. Is all of this done before placing in the new ssd card or after. I don’t have any files that I would like to safe/transfer, is all of this necessary, if I don’t do it before placing new ssd, will I still be able to instal/upgrade macOS afterwards.
It’s an old Mac and now it won’t start or charge, I know I will have to replace battery and put new battery first and turn on Mac before doing the ssd stuff. Since it won’t effing start.
I’m really clueless about backing up old ssd, since I don’t need any files, besides MacOS(software) ,and is that related to the ssd?
AMG - Replica
The answer to your question: You need to insert your SSD into the computer before internet recovery. If you start the recovery before inserting SSD, it won’t affect the setup, you won’t damage anything. But your SSD will not be detected (as there isn’t one inserted.)
Also, a little tip: If you bought a used SSD, go into Disk Utility and format the drive with the highest security level to permanently remove all of the previous files.
Also a FYI: Internet Recovery will load up Mac OS X 10.9.5 Mavericks, so I would recommend making a recovery drive from a Big Sur (or desired version) through another Mac, and a USB. You can visit this support doc: https://support.apple.com/en-us/HT201372
Hope this helps! -Dan
danielwen -
I got a macbook air with a damaged and swollen battery. I could remove all screws, except one 2,5 mm screw. I’m afraid it got damaged while attempting to remove it, I have no grip with the P5 pentalobe screwdriver. How can I proceed?
Robert Hermans - Replica
Hi Robert!
Try some techniques found in this stripped screw removal guide. Good luck!
Arthur Shi -
Hello I have a macbook air they are say they do not have parts for my laptop macbook air 11 inches 2013 mid need to replace battery which one to buy
vensilver - Replica
Hello! This is the part you want—maybe we’re not able to ship it to you if you’re out of the United States. The battery in your MacBook Air should be the same for all 11” between mid-2011 to early-2015.
Arthur Shi -
The smaller screws went in more easily when I put back all the screws along the hinge edge first.
Rachel Slatkin - Replica
