Introduzione
Use this guide to replace the I/O board to remedy a broken headphone jack, left USB port, or MagSafe DC-In socket.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Remove the following five screws securing the battery to the upper case:
Two 5.2 mm T5 Torx screws
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
Altre 13 persone hanno completato questa guida.
2 Commenti
My computer doesn’t have any audio device whenever I look at the “device manager” (I don’t remember the Mac OS name). It started after I dropped it almost perpendicularly to the floor, so I wonder whether the problem is with this daughter board or the main one… 🤔 Any ideas? The USB and magsafe ports work, but not the embedded microphone, nor the output jack, nor the speakers. :(
Replying to my past self:
The I/O board cable was not fully seated on the main board. I guess the shock made it move because the adhesive was already ripped and did not absorb the shock.
Hurray! I made a free repair job on my laptop! 😅
