Salta al contenuto principale
MacBook Air 11" Mid 2011 Lower Case Replacement
Cosa ti serve
  1. MacBook Air 11" Mid 2011 Lower Case Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Compra
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2011 Lower Case Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Conclusione
Altre 10 persone hanno completato questa guida.
Un commento
Super easy guide. Parts quality may vary depending on dents or other aesthetics. I recommend buying plastic feet just in case you need them and as a backup to existing inventory.
Al N - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 76
Tutti i Tempi: 13,242
