Salta al contenuto principale
Introduzione
Use this guide to replace the AirPort/Bluetooth board and restore network connectivity to your MacBook Air.
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  1. MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement, Battery Connector: passo 3, immagine 1 di 2 MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement, Battery Connector: passo 3, immagine 2 di 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  3. MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: passo 4, immagine 1 di 3 MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: passo 4, immagine 2 di 3 MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: passo 4, immagine 3 di 3
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way of the card.
  4. MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement: passo 5, immagine 1 di 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  5. MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement: passo 6, immagine 1 di 3 MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement: passo 6, immagine 2 di 3 MacBook Air 11" Early 2014 AirPort/Bluetooth Board Replacement: passo 6, immagine 3 di 3
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it straight out of its socket on the logic board.
    • To avoid damaging the socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
Conclusione
Altre 5 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 44
Tutti i Tempi: 4,990
