Introduzione
The bottom housing holds all your mini's internals.
Cosa ti serve
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
We will first remove the AirPort antenna, located in the lower left corner of this picture.
Use the flat end of a spudger to pry the three antenna connectors off the AirPort/Bluetooth combo card.
Use the flat end of a spudger to pry the power button cable connector up off the logic board.
Remove the single Phillips screw between the headphone and microphone jacks on the audio board.
Altre 3 persone hanno completato questa guida.
