Introduzione
Replace a broken AirPort card to regain wireless connectivity.
Parti
Nessuna parte specificata.
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Use the flat end of a spudger to pry the AirPort antenna cable connector up off the AirPort card.
Remove the single Phillips screw securing the AirPort card to the logic board.
Altre 25 persone hanno completato questa guida.
