Salta al contenuto principale
Mac mini Mid 2011 Bottom Cover Replacement
Cosa ti serve
  1. Mac mini Mid 2011 Bottom Cover Replacement, Bottom Cover: passo 1, immagine 1 di 2 Mac mini Mid 2011 Bottom Cover Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
  2. Mac mini Mid 2011 Bottom Cover Replacement: passo 2, immagine 1 di 1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
Linea Traguardo
Altre 17 persone hanno completato questa guida.
2 Commenti
The base plate on my MM has no thumb dimples, no “lock dots”, and it won’t budge. I’ve tried everything short of prying it off—light touch, firm touch, thumbs, palm, nothing has worked. Any suggestions?
Jonathan Royce - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 50
Tutti i Tempi: 24,339
