Salta al contenuto principale
Mac mini (PowerPC) Speaker Replacement
Cosa ti serve
  1. Mac mini (PowerPC) Speaker Replacement, Top Housing: passo 1, immagine 1 di 2 Mac mini (PowerPC) Speaker Replacement, Top Housing: passo 1, immagine 2 di 2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
  2. Mac mini (PowerPC) Speaker Replacement: passo 2, immagine 1 di 3 Mac mini (PowerPC) Speaker Replacement: passo 2, immagine 2 di 3 Mac mini (PowerPC) Speaker Replacement: passo 2, immagine 3 di 3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Mac mini (PowerPC) Speaker Replacement: passo 3, immagine 1 di 2 Mac mini (PowerPC) Speaker Replacement: passo 3, immagine 2 di 2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini (PowerPC) Speaker Replacement: passo 4, immagine 1 di 2 Mac mini (PowerPC) Speaker Replacement: passo 4, immagine 2 di 2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini (PowerPC) Speaker Replacement: passo 5, immagine 1 di 2 Mac mini (PowerPC) Speaker Replacement: passo 5, immagine 2 di 2
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini (PowerPC) Speaker Replacement: passo 6, immagine 1 di 2 Mac mini (PowerPC) Speaker Replacement: passo 6, immagine 2 di 2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
  7. Mac mini (PowerPC) Speaker Replacement, Mass Storage Unit: passo 7, immagine 1 di 1
    • If your mini does not have Airport installed, then skip this step.
    • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
  8. Mac mini (PowerPC) Speaker Replacement: passo 8, immagine 1 di 1
    • Remove the yellow tape securing the power button cable to the black plastic framework.
  9. Mac mini (PowerPC) Speaker Replacement: passo 9, immagine 1 di 1
    • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
  10. Mac mini (PowerPC) Speaker Replacement: passo 10, immagine 1 di 1
    • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
  11. Mac mini (PowerPC) Speaker Replacement: passo 11, immagine 1 di 1
    • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
    • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
  12. Mac mini (PowerPC) Speaker Replacement, Hard Drive: passo 12, immagine 1 di 1
    • Remove the three long, black Phillips screws from the corners of the fan. These screws are strongly threaded, and will offer significant resistance.
    • There is no screw in the bottom left corner.
  13. Mac mini (PowerPC) Speaker Replacement: passo 13, immagine 1 di 1
    • Lift the fan out of the computer.
  14. Mac mini (PowerPC) Speaker Replacement: passo 14, immagine 1 di 1
    • Peel up the yellow tape securing the speaker and fan cables to the bottom of the hard drive.
  15. Mac mini (PowerPC) Speaker Replacement: passo 15, immagine 1 di 1
    • Use a #1 Phillips to remove the two screws attaching the right side of the hard drive to the plastic framework. You'll need to angle the screwdriver down to get access to the lower right screw. Be sure to apply steady force to the screws and turn slowly so as not to strip them.
  16. Mac mini (PowerPC) Speaker Replacement: passo 16, immagine 1 di 1
    • Use the same screwdriver and steady force to remove the two screws attaching the left side of the hard drive to the plastic framework.
  17. Mac mini (PowerPC) Speaker Replacement: passo 17, immagine 1 di 1
    • Use a spudger to pry the hard drive away from the interface board. Wedge the flat end of the spudger between the interface board and the far right side of hard drive and wiggle back and forth until the hard drive slides out about a sixteenth of an inch. Then move to the other side and repeat the procedure. Go back and forth until the hard drive slides free.
    • When reinstalling the hard drive, make sure that you don't slide the top pins into the lower row of holes.
  18. Mac mini (PowerPC) Speaker Replacement: passo 18, immagine 1 di 1
    • Lift the hard drive out of the assembly.
  19. Mac mini (PowerPC) Speaker Replacement, Speaker: passo 19, immagine 1 di 1
    • While holding the assembly with the speaker resting on the table, remove the four black Phillips screws holding the speaker in place and their associated rubber bumpers.
    • When replacing the speaker, place the rubber bumpers into the plastic casing first, then slide the screws into them, and finally line up the speaker with the screws. When working on the lower screws, you'll need to angle the end of the screw up a bit, as the speaker sits higher on the framework than you might expect.
  20. Mac mini (PowerPC) Speaker Replacement: passo 20, immagine 1 di 1
    • Deroute the speaker cable from the plastic framework, removing tape as necessary.
  21. Mac mini (PowerPC) Speaker Replacement: passo 21, immagine 1 di 1
    • The cable you're about to remove is very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using your fingernails or a small flathead screwdriver if necessary.
    • Disconnect the speaker connector from the interface board.
    • Pull the speaker out from the plastic framework.
Conclusione
Altre 2 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 5,256
