Salta al contenuto principale
Mac Studio 2023 Power Supply Replacement
Cosa ti serve
  1. Mac Studio 2023 Power Supply Replacement, Prepare your Mac Studio for disassembly: passo 1, immagine 1 di 3 Mac Studio 2023 Power Supply Replacement, Prepare your Mac Studio for disassembly: passo 1, immagine 2 di 3 Mac Studio 2023 Power Supply Replacement, Prepare your Mac Studio for disassembly: passo 1, immagine 3 di 3
    • Completely shut down your Mac Studio.
    • Unplug all cables from your device.
  2. Mac Studio 2023 Power Supply Replacement, Flip your Mac Studio over: passo 2, immagine 1 di 1
    • Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
  3. Mac Studio 2023 Power Supply Replacement, Heat the bottom cover screw pad: passo 3, immagine 1 di 3 Mac Studio 2023 Power Supply Replacement, Heat the bottom cover screw pad: passo 3, immagine 2 di 3 Mac Studio 2023 Power Supply Replacement, Heat the bottom cover screw pad: passo 3, immagine 3 di 3
    • Adhesive strips secure the bottom cover screw pad.
    • Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
    • You can also use a hair dryer or heat gun, but be careful as extreme heat will warp the pad.
  4. Mac Studio 2023 Power Supply Replacement, Lift a section of bottom cover screw pad: passo 4, immagine 1 di 3 Mac Studio 2023 Power Supply Replacement, Lift a section of bottom cover screw pad: passo 4, immagine 2 di 3 Mac Studio 2023 Power Supply Replacement, Lift a section of bottom cover screw pad: passo 4, immagine 3 di 3
    • Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
    • This may take some force. If you're having trouble, apply more heat and try again.
    • Use the spudger to lift the pad and separate the adhesive.
  5. Mac Studio 2023 Power Supply Replacement, Separate the remaining adhesive: passo 5, immagine 1 di 3 Mac Studio 2023 Power Supply Replacement, Separate the remaining adhesive: passo 5, immagine 2 di 3 Mac Studio 2023 Power Supply Replacement, Separate the remaining adhesive: passo 5, immagine 3 di 3
    • Insert the flat end of a spudger under the pad.
    • Slide the spudger under the entire pad to separate the remaining adhesive.
  6. Mac Studio 2023 Power Supply Replacement, Remove the bottom cover screw pad: passo 6, immagine 1 di 1
    • Remove the bottom cover screw pad.
  7. Mac Studio 2023 Power Supply Replacement, Reassembly information: passo 7, immagine 1 di 3 Mac Studio 2023 Power Supply Replacement, Reassembly information: passo 7, immagine 2 di 3 Mac Studio 2023 Power Supply Replacement, Reassembly information: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Tesa 61395 Tape
    $2.99
    • During reassembly:
    • If the adhesive strips are still sticky, you can reuse them.
    • If you're applying new adhesive:
    • Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
    • Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
    • If you don't have replacement adhesive, you can use strips of thin, double-sided tape 2–3 mm wide.
    • Apply the new adhesive strips to the bottom cover and remove their liners.
    • Firmly press the bottom cover screw pad into its recess to secure it.
  8. Mac Studio 2023 Power Supply Replacement, Remove the bottom cover screws: passo 8, immagine 1 di 2 Mac Studio 2023 Power Supply Replacement, Remove the bottom cover screws: passo 8, immagine 2 di 2
    FixMat
    $31.41
    • While the Mac Studio uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came.
  9. Mac Studio 2023 Power Supply Replacement, Remove the bottom cover: passo 9, immagine 1 di 3 Mac Studio 2023 Power Supply Replacement, Remove the bottom cover: passo 9, immagine 2 di 3 Mac Studio 2023 Power Supply Replacement, Remove the bottom cover: passo 9, immagine 3 di 3
    • Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
    • Remove the bottom cover.
    • To orient the bottom cover, align the Kensington lock cutout in the top left corner with the corresponding one on the internal frame.
  10. Mac Studio 2023 Power Supply Replacement, Remove the power supply screws: passo 10, immagine 1 di 2 Mac Studio 2023 Power Supply Replacement, Remove the power supply screws: passo 10, immagine 2 di 2
    • Use a T10 Torx screwdriver to remove the six screws securing the power supply:
    • Four 6 mm‑long screws
    • Two 7 mm‑long screws with washers
    • You may need to remove a sticker to access these screws. If you do, save it for reassembly.
  11. Mac Studio 2023 Power Supply Replacement, Reposition your Mac Studio: passo 11, immagine 1 di 1
    • Flip your Mac Studio around so the rear ports are facing you.
  12. Mac Studio 2023 Power Supply Replacement, Disconnect the power cord port cable: passo 12, immagine 1 di 3 Mac Studio 2023 Power Supply Replacement, Disconnect the power cord port cable: passo 12, immagine 2 di 3 Mac Studio 2023 Power Supply Replacement, Disconnect the power cord port cable: passo 12, immagine 3 di 3
    • A tight plastic latch secures the power cord port cable.
    • Firmly hold the power supply with one hand and lift up the edge near the power cord port.
    • With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
  13. Mac Studio 2023 Power Supply Replacement, Tilt up the power supply: passo 13, immagine 1 di 1
    • Only grab the power supply by its edges. Various power components and capacitors are left exposed.
    • Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
    • Be careful not to strain the cable that's still connected to the power supply.
    • Keep the power supply tilted up for the next step.
  14. Mac Studio 2023 Power Supply Replacement, Disconnect the power supply signal cable: passo 14, immagine 1 di 3 Mac Studio 2023 Power Supply Replacement, Disconnect the power supply signal cable: passo 14, immagine 2 di 3 Mac Studio 2023 Power Supply Replacement, Disconnect the power supply signal cable: passo 14, immagine 3 di 3
    • A delicate plastic clip secures the power supply signal cable.
    • With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
  15. Mac Studio 2023 Power Supply Replacement, Remove the power supply: passo 15, immagine 1 di 1
    • Remove the power supply.
Conclusione
Spencer Day
Membro da: 09/14/22
149.272 Reputazione
995 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.608 Guide realizzate
1Commento della guida
Hello,
Mon Mac Studio M1 a le fameux problème du bloc d’alimentation…
Je souhaite changer le pièce mais on ne la trouve pas sur le store ?
Où puis-je trouver cette pièce ?
Merci.
Pierre Bena - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 171
Tutti i Tempi: 1,729
