Introduzione
Use this guide to replace a broken power button in your Mac Studio (2023).
If the power button isn't clicking properly or doesn't work at all, it may be time to replace the button.
Before starting this repair, read through Apple's troubleshooting article and try the solutions that don't require taking apart your device.
A faulty power supply could also be the reason your device isn't turning on. If that's the case, you'll need to replace it.
Cosa ti serve
Completely shut down your Mac Studio.
Unplug all cables from your device.
Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
Use the spudger to lift the pad and separate the adhesive.
Insert the flat end of a spudger under the pad.
Slide the spudger under the entire pad to separate the remaining adhesive.
Attrezzo utilizzato in questo passaggio:Tesa 61395 Tape$2.99
If the adhesive strips are still sticky, you can reuse them.
Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
Apply the new adhesive strips to the bottom cover and remove their liners.
Firmly press the bottom cover screw pad into its recess to secure it.
Attrezzo utilizzato in questo passaggio:FixMat$31.41
Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
Remove the bottom cover.
Use a T10 Torx screwdriver to remove the six screws securing the power supply:
Four 6 mm‑long screws
Two 7 mm‑long screws with washers
Flip your Mac Studio around so the rear ports are facing you.
Firmly hold the power supply with one hand and lift up the edge near the power cord port.
With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
Keep the power supply tilted up for the next step.
With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
Seven 5 mm‑long screws
One 4 mm‑long screw
Slowly lift the internal frame straight up and remove it, making sure no cables get snagged.
Use a T5 Torx screwdriver to remove the two 12 mm‑long screws securing the speaker.
Lift the inner edge of the speaker and stand it upright so you can access its connector on the logic board.
Insert the point of a spudger under the speaker connector's plastic head and carefully lift it straight up and out of its socket.
Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the I/O board cable cover.
Use a T8 Torx screwdriver to remove the standoff screw just to the right of the cover.
Use a spudger to pry up and disconnect both of the I/O board's press connectors.
Use the point of a spudger or a clean fingernail to flip up the hinged locking flap on the power button cable ZIF connector, located on the outer edge of the I/O board.
Use tweezers to gently pull the cable straight out of its socket.
Carefully stand up your Mac Studio so the SD card reader and two front USB-C ports are facing up.
Attrezzo utilizzato in questo passaggio:Flexible Extension$6.99
Use a T4 Torx screwdriver to remove the two 15.5 mm‑long screws securing the outer edge of the I/O board.
Use a T6 Torx screwdriver to remove the two 20 mm‑long screws securing the inner edge of the I/O board.
Partially tighten the four screws securing the board.
Lay your Mac Studio down and plug a cable into one of the ports to ensure proper fit and alignment, adjusting the port as necessary—the cable should be easy to insert and remove.
With the cable plugged in and the board in position, fully tighten all four screws.
Unplug all cables before continuing.
Lift the I/O board straight up and out of its recess to remove it.
Use a T3 Torx screwdriver to remove the three 7.6 mm‑long screws securing the power button.
