Salta al contenuto principale
Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock
Cosa ti serve
  1. Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock, Remove Enclosure: passo 1, immagine 1 di 1
    • Remove the enclosure by sliding the latch to the right and lifting the enclosure up.
    • Using a T5 screwdriver, remove the six screws retaining the latch on the inside of the enclosure and lift out the retainer plate.
  2. Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock, Replace latch with modified version: passo 3, immagine 1 di 1
    • Remove the original latch, install the replacement latch with Kensington lock hole, and restore the retainer plate and six screws.
  3. Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock, Install Cable Lock: passo 4, immagine 1 di 1
    • Return the enclosure and slide the latch back to the left. Install cable lock into the exposed hole.
Conclusione
This guide will help you secure your Mac Pro (2013) with any cable lock.
Kemper Barkhurst
Membro da: 07/30/15
149 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 36
Tutti i Tempi: 2,184
