Salta al contenuto principale
Mac Pro Late 2013 AirPort Antenna Array Replacement
Cosa ti serve
  1. Mac Pro Late 2013 AirPort Antenna Array Replacement, Outer Case: passo 1, immagine 1 di 2 Mac Pro Late 2013 AirPort Antenna Array Replacement, Outer Case: passo 1, immagine 2 di 2
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 2, immagine 1 di 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 2, immagine 2 di 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 2, immagine 3 di 3
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: passo 3, immagine 1 di 3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: passo 3, immagine 2 di 3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly: passo 3, immagine 3 di 3
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 4, immagine 1 di 2 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 4, immagine 2 di 2
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 5, immagine 1 di 1
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 6, immagine 1 di 1
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 7, immagine 1 di 2 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 7, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 8, immagine 1 di 1
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  9. Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: passo 9, immagine 1 di 3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: passo 9, immagine 2 di 3 Mac Pro Late 2013 AirPort Antenna Array Replacement, Fan Assembly Lid: passo 9, immagine 3 di 3
    • Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
    • Remove the fan assembly lid.
  10. Mac Pro Late 2013 AirPort Antenna Array Replacement, AirPort Board: passo 10, immagine 1 di 1
    • Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
  11. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 11, immagine 1 di 1
    • Lift and remove the metal cover from the AirPort board bay.
  12. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 12, immagine 1 di 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 12, immagine 2 di 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 12, immagine 3 di 3
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector.
    • Remove the fan assembly ribbon cable from its ZIF socket.
  13. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 13, immagine 1 di 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 13, immagine 2 di 3 Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 13, immagine 3 di 3
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable.
    • Disconnect the fan ribbon cable.
  14. Mac Pro Late 2013 AirPort Antenna Array Replacement, AirPort Antenna Array: passo 14, immagine 1 di 1
    • Remove the three 3.7 mm T4 screws securing the antenna array to the fan assembly.
  15. Mac Pro Late 2013 AirPort Antenna Array Replacement: passo 15, immagine 1 di 1
    • Remove the AirPort antenna array.
Conclusione
Altre 3 persone hanno completato questa guida.
iFixit Membro di iFixit
Community
139 Membri
16.890 Guide realizzate
2 Commenti
having macpro 2013 bluetooth on issue, where is the bluetooth module locate?
Sanong - Replica
is bluetooth module part of (inside) airport board?
Sanong - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 35
Tutti i Tempi: 4,704
