Salta al contenuto principale
Mac Pro First Generation Optical Drive Replacement
Cosa ti serve
  1. Mac Pro First Generation Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 1
    • Lift the lever to unlock the case
  2. Mac Pro First Generation Optical Drive Replacement: passo 2, immagine 1 di 1
    • Remove the side panel of the Mac Pro
  3. Mac Pro First Generation Optical Drive Replacement: passo 3, immagine 1 di 3 Mac Pro First Generation Optical Drive Replacement: passo 3, immagine 2 di 3 Mac Pro First Generation Optical Drive Replacement: passo 3, immagine 3 di 3
    • Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
  4. Mac Pro First Generation Optical Drive Replacement: passo 4, immagine 1 di 1
    • Firmly hold each of the two connectors and pull them out of their respective sockets.
  5. Mac Pro First Generation Optical Drive Replacement: passo 5, immagine 1 di 2 Mac Pro First Generation Optical Drive Replacement: passo 5, immagine 2 di 2
    • Unscrew the shown two 6-32 type screws on each side of the optical drive.
  6. Mac Pro First Generation Optical Drive Replacement: passo 6, immagine 1 di 2 Mac Pro First Generation Optical Drive Replacement: passo 6, immagine 2 di 2
    • Firmly grasp the optical drive and pull it out of its enclosure.
    To make the pull easier without pluming the whole body over- pull with your fingers and brace your thumbs on the tower chassis above - worked for me.
    Nick Rogers - Replica
    Correction, for pluming read pulling!
Conclusione
Altre 21 persone hanno completato questa guida.
Derek Chan
Membro da: 10/13/14
1.416 Reputazione
1 Guida realizzata
Cal Poly, Team 6-24, Maness Fall 2014 Membro di Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Membri
13 Guide realizzate
10 Commenti
Thanks! It had been a long time since I'd been inside my towers! Easy-peasy!
Janie Wilson-Cook - Replica
I am having problems with the new optical drive not being able to eject and close without my help. Any thoughts?
footeking - Replica
Did you take off the front of the tray?
nbeijer -
Awesome!!! Worked like a charm! Drive is totally busted. Do you have a link or a suggestion for an optical drive for a late 2009 Mac pro? Thanks either way!
Jay Haser - Replica
The unit holding the optical drive will NOT pull out at all and I and really pulling on it and wiggling it. All other videos show it popping out with little force. What am I doing wrong?
pipevape - Replica
I am having the same problem did you figure out what was wrong?
Tony Bounsall -
Probably just stuck. I’ve had mine out several times before, but the lever at the back of the case must be open. When it’s closed, it locks it in.
Aquenon -
I am having the same problem . I raised the lever handle no problem---Is there another interlock ?
Chuck Hendricks -
I am having the same problem. The lever arm comes up and stays up no Problem. Is there another interlock to release the optical drive door ?
vamochuck@gmail.com
Chuck Hendricks -
I am having the same problem. Any solution ?
vamochuck@gmail.com
Chuck Hendricks -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 63
Tutti i Tempi: 16,761
