Salta al contenuto principale
Mac Pro First Generation Hard drives and hard drive carriers (Early 2008)
Cosa ti serve
  1. Mac Pro First Generation Hard drives and hard drive carriers (Early 2008), Opening the Computer (2006-2008): passo 1, immagine 1 di 2 Mac Pro First Generation Hard drives and hard drive carriers (Early 2008), Opening the Computer (2006-2008): passo 1, immagine 2 di 2
    • Shut down the computer.
    • Warning: Always shut down the computer before opening it to avoid damaging its internal components or the components you are installing. Do not open the computer or attempt to install items inside it while it is on.
    • Wait 5 to 10 minutes to allow the computer’s internal components to cool.
    • Warning: After you shut down the system, the internal components can be very hot. You must let the computer cool down before continuing.
    • Unplug all external cables from the computer except the power cord.
    • Touch the metal PCI access covers on the back of the computer to discharge any static electricity from your body.
    • Unplug the power cord.
    • Put on an ESD wrist strap.
    Updated to reflect same procedure for all models in range
    DavidM - Replica
  2. Mac Pro First Generation Hard drives and hard drive carriers (Early 2008): passo 2, immagine 1 di 1
    • 1) Hold the side access panel and lift the latch on the back of the computer.
    • Warning: The edges of the access panel and the enclosure can be sharp. Be very careful when handling them.
    • 2) Remove the access panel and place it on a flat surface covered by a soft, clean cloth.
    • Replacement Note: Make sure the latch is in the up position before replacing the access panel. If the latch is down, the access panel will not seat correctly in the enclosure.
    Is this the actual width of the drive or the internal layout.
    Stephen - Replica
  3. Mac Pro First Generation Hard drives and hard drive carriers (Early 2008), Hard drives and hard drive carriers (Early 2008): passo 3, immagine 1 di 1
    • The hard drives must meet the following specifications:
    • Type: Serial Attached SCSI (SAS) or Serial ATA (SATA) 3 Gb/s
    • Width: 3.9 inches (102 mm)
    • Depth: 5.7 inches (147 mm)
    • Height: 1.0 inch
    Can you add an ssd by any chance ?
    London Asylum Records - Replica
  4. Mac Pro First Generation Hard drives and hard drive carriers (Early 2008): passo 4, immagine 1 di 1
    • Important: To install SAS drives in a Mac Pro (Early 2008) computer, you must also install the optional Mac Pro RAID Card.
  5. Mac Pro First Generation Hard drives and hard drive carriers (Early 2008): passo 5, immagine 1 di 1
    • Before you begin, open the computer, and lay it on its side with the access side facing up.
    • Important: Make sure the latch on the back panel is in the up position. When the latch is down, the hard drives and carriers are locked in place and you will not be able to remove them.
  6. Mac Pro First Generation Hard drives and hard drive carriers (Early 2008): passo 6, immagine 1 di 1
    • Make sure the latch on the back panel is up, so that the drives and carriers are unlocked.
    • Pull the hard drive out of the drive bay.
  7. Mac Pro First Generation Hard drives and hard drive carriers (Early 2008): passo 7, immagine 1 di 1
    • If you are replacing the hard drive with a new drive, remove the four screws that mount the 3. drive to the carrier and mount the new drive in the carrier.
    • Important: Hold the drive by its sides. Be careful not to touch the printed circuit board on the bottom of the drive.
    • Replacement Note: Slide the carrier and drive over the guides and into the drive bay, until you feel the drive snap into place.
Conclusione
Altre 16 persone hanno completato questa guida.
Joshua Byrne
Membro da: 05/03/13
7.665 Reputazione
10 Guide realizzate
Un commento
Success - I just wanted to remove the hard drive because my poor old Mac Pro has more problems than I can deal with. I wish the solution were as simple as replacing the hard drive, but at least I have that to reuse if I wish.
ccdavid1 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 37
Tutti i Tempi: 13,761
