Strumenti
Parti
Nessuna parte richiesta.
Open the Case Shut down your Mac Pro, give it a few minutes to cool off, and unplug all the wires and cables. Locate the latch on the back of the case and pull it out. The latch lifts out very easily and stops after an inch or two — do not try to force it any farther.
Each bay has a number stamped on it, and they go in order from left to right. Bay #1 should contain the stock hard drive that was installed by Apple. Gently remove the bracket from the next empty hard drive bay — if you only purchased one hard drive with your computer, this should be bay it should easily slide out.
Altre 33 persone hanno completato questa guida.
