Salta al contenuto principale
Mac Pro 2009-2012 CPU Replacement
Cosa ti serve
  1. Mac Pro 2009-2012 CPU  Replacement, Pull out CPU tray: passo 1, immagine 1 di 3 Mac Pro 2009-2012 CPU  Replacement, Pull out CPU tray: passo 1, immagine 2 di 3 Mac Pro 2009-2012 CPU  Replacement, Pull out CPU tray: passo 1, immagine 3 di 3
    • Find the 2 pull tabs and use them to pull out the CPU tray and place them on the table.
    • Use a hex wrench to unscrew the spring-loaded screw using the star pattern on the CPU Heatsink for even force of the CPU die. This is a specially needed when putting the Heatsink back on.
    • Turn the hex wrench once each time until it's loose when Using the star pattern (Diagram shown).
    • On 2009 (4,1) Mac Pros, The CPU comes up with the Heatsink and is not socketed. Like the 2010-2012 (5,1) Mac Pros.
    • Pull Straight up as there is a vital connection built into the heatsink.
    • On the bottom of the heatsink will be a copper pad that comes in contact with the CPU. Use a paper towel to wipe off all the remaining thermal paste, isopropyl Alcohol is handy for this.
    • Isopropyl alcohol is handy for getting the best for cleaning the Copper Heatsink&CPU for new thermal paste.
  2. Mac Pro 2009-2012 CPU  Replacement, CPU replacement: passo 2, immagine 1 di 3 Mac Pro 2009-2012 CPU  Replacement, CPU replacement: passo 2, immagine 2 di 3 Mac Pro 2009-2012 CPU  Replacement, CPU replacement: passo 2, immagine 3 di 3
    • Clean all of the thermal paste on the CPU and lift the metal bar up and pull the bracket back.
    • Gently pull out the old CPU with thumb and pointer finger and then place it towards the side.
    • Don't touch the exposed connectors on the CPU to the CPU tray.
  3. Mac Pro 2009-2012 CPU  Replacement, New CPU: passo 3, immagine 1 di 3 Mac Pro 2009-2012 CPU  Replacement, New CPU: passo 3, immagine 2 di 3 Mac Pro 2009-2012 CPU  Replacement, New CPU: passo 3, immagine 3 di 3
    • Inspect the cpu socket and other connectors for dust and debris and blow away if necessary.
    • Place the new cpu in with a touch of thermal paste at the top.
Conclusione
Altre 4 persone hanno completato questa guida.
3Commenti sulla guida
This process shows a single CPU MacPro, which gets a Xeon processor WITH the LID covering it and heatsink on it. As of MacPro4,1 with Nehalem it's bi-xeon CPU and heatsink on a bare processor chip, no lid covers. That difference cannot be seen from a built MacPro board (because of the big heatsinks-) But it's a good performance improvement (CPU temp the lower the faster) when heatsink's directly in contact with the chip.
https://superuser.com/questions/923678/d...
If you can buy a Xeon upgrade just be sure to choose the processor without the lid (most Apple Mac setups) or with the lid cover (as PC setups)
Ti B Rakotoarima - Replica
Your guide has been very useful. Best compliments. I'll follow you 4ever!
aureliogiovanardi - Replica
Glad to here!
Thanks for the positive feedback! @goodyb Good job!
Ben Capehart -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 48
Ultimi 30 Giorni: 208
Tutti i Tempi: 8,846
