Salta al contenuto principale
Mac Powerbook 140 Battery Replacement
Cosa ti serve
  1. Mac Powerbook 140 Battery  Replacement, Aquire Battery: passo 1, immagine 1 di 1
    • Begin by locating the correct type of battery. A simple internet search or a glance at Amazon.com should bring the right results. BE SURE THAT THE BATTERY IS COMPATIBLE WITH THE COMPUTER. Not doing so could result in injury.
  2. Mac Powerbook 140 Battery  Replacement, Remove Original Battery: passo 2, immagine 1 di 1
    • Slide the battery panel ( or switch, depending on the battery) on the left side of the computer so the battery is in the "Unlocked" position. Pull the battery straight out. Put in the new battery and slide the panel/switch to the "Locked" position.
Conclusione
It is not required, but I always find it useful to save the old battery, lest you need it later. Unless the battery is leaking, or poses some other health/safety issue(in which case dispose of it in the proper manner), store it in a battery-safe environment.
Altre 2 persone hanno completato questa guida.
Jack
Membro da: 10/23/15
786 Reputazione
3 Guide realizzate
Un commento
I can’t find a replacement battery anywhere, they’re either out of stock or in another powerbook on ebay and those cost $80 with the chance that the battery in them is dead too.
BCG04 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,617
