Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This is a guide describing how to replace the feet on 2009-2012 MacBook and MacBook Pros. For a full guide including lower case removal, refer to the specific MacBook model's device page.
  1. Remove any broken or damaged feet. Remove any pieces from the old foot that may have broken off in the foot hole. Use tweezers to peel up and remove the old adhesive tape from the foot pad.
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  2. Scrub the foot pad with adhesive remover to remove any remaining adhesive.
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Acquista ora
    Acquista ora
  4. Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  5. Peel a replacement foot from the plastic backing.
    • Peel a replacement foot from the plastic backing.
  6. Align the new foot inside the foot pad. Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad. Lay the foot down while keeping it properly aligned.
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  7. Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
Conclusione
Arthur Shi
Membro da: 03/01/2018
139.046 Reputazione
388 Guide realizzate
iFixit Membro di iFixit
Community
131 Membri
13.426 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 269
