Salta al contenuto principale
MSI PR600 MS-16372 Key Replacement
Cosa ti serve
  1. MSI PR600 MS-16372 Key Replacement, Key: passo 1, immagine 1 di 1
    • Before you begin this replacement, make sure to turn the computer off to prevent future problems from occurring.
    • Start by flipping the laptop upside down and shake it gently to release excess debris.
  2. MSI PR600 MS-16372 Key Replacement: passo 2, immagine 1 di 1
    • Place flathead screwdriver underneath the faulty key.
    • Lift the flathead screwdriver upwards until you hear a click and it releases off the keyboard.
  3. MSI PR600 MS-16372 Key Replacement: passo 3, immagine 1 di 1
    • Gently brush off any loose particles that could be found underneath the key.
  4. MSI PR600 MS-16372 Key Replacement: passo 4, immagine 1 di 1
    • Align key to the center of the button and press down until you hear it click.
    • If you do not apply enough pressure the key will not fully reattach, so make sure you press hard enough.
Conclusione
Lauren Mewes
Membro da: 10/21/18
361 Reputazione
3 Guide realizzate
UC Davis, Team S4-G8, Lore Fall 2018 Membro di UC Davis, Team S4-G8, Lore Fall 2018
UCD-LORE-F18S4G8
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 341
