Salta al contenuto principale
MSI PR600 MS-16372 Battery Replacement
  1. MSI PR600 MS-16372 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • First, turn off the computer and unplug the power cord.
    • If laptop is not unplugged from the power cord, you could be at risk of electric shock.
  2. MSI PR600 MS-16372 Battery Replacement: passo 2, immagine 1 di 1
    • Flip laptop over so that you are looking at the bottom of the laptop.
    • Put your left pointer finger on the switch labeled "Battery lock" and your right pointer finger on the switch labeled "Release".
  3. MSI PR600 MS-16372 Battery Replacement: passo 3, immagine 1 di 1
    • Switch the tab labeled "Battery lock" to the unlocked position.
    • Slide the tab labeled "Release" to the right and hold it down.
    • While holding the "Release" tab to the right, slide the battery out with your left hand.
Conclusione
Lauren Mewes
Membro da: 10/21/18
361 Reputazione
3 Guide realizzate
UC Davis, Team S4-G8, Lore Fall 2018 Membro di UC Davis, Team S4-G8, Lore Fall 2018
UCD-LORE-F18S4G8
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 330
