Salta al contenuto principale
MSI PE70 6QE-035US speaker Replacement
Cosa ti serve
  1. MSI PE70 6QE-035US speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Start by flipping the device over to the backside.
    • Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
  2. MSI PE70 6QE-035US speaker Replacement: passo 2, immagine 1 di 2 MSI PE70 6QE-035US speaker Replacement: passo 2, immagine 2 di 2
    • After you remove the back panel, you should now see the 3 speakers.
    • We will start with the bottom most speaker.
  3. MSI PE70 6QE-035US speaker Replacement: passo 3, immagine 1 di 2 MSI PE70 6QE-035US speaker Replacement: passo 3, immagine 2 di 2
    • Using the ifixit opening tool, remove the speaker by gently unplugging its cord from the motherboard. Be sure to unplug the cord in the direction shown by the arrow.
    • After the cord has been unplugged, the speaker should now be able to be lifted out.
  4. MSI PE70 6QE-035US speaker Replacement: passo 4, immagine 1 di 3 MSI PE70 6QE-035US speaker Replacement: passo 4, immagine 2 di 3 MSI PE70 6QE-035US speaker Replacement: passo 4, immagine 3 di 3
    • These two speakers will be taken out together because they are held in by the same cord.
    • Once you have unplugged the cord, both speakers should be able to be lifted out.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 151
