Salta al contenuto principale
MSI PE70 6QE-035US Fan Replacement
Cosa ti serve
  1. MSI PE70 6QE-035US Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Start by flipping the device over to the backside.
    • Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
  2. MSI PE70 6QE-035US Fan Replacement: passo 2, immagine 1 di 1
    • after the back of the laptop is off, unscrew all the black and silver screws holding in the heat sink and fan covers.
    • There should be 8 silver, 6 black, and 14 screws in total.
  3. MSI PE70 6QE-035US Fan Replacement: passo 3, immagine 1 di 2 MSI PE70 6QE-035US Fan Replacement: passo 3, immagine 2 di 2
    • disconnect the wires that go from the fans to the motherboard.
    • then remove the fans from the mother board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 139
