Salta al contenuto principale
MSI MS-1782 Back Cover Replacement
Cosa ti serve
  1. MSI MS-1782 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Back Cover Replacement: passo 2, immagine 1 di 3 MSI MS-1782 Back Cover Replacement: passo 2, immagine 2 di 3 MSI MS-1782 Back Cover Replacement: passo 2, immagine 3 di 3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 328
