Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo MSI Katana 15 B13V, usa il nostro manuale di assistenza.
    • The first step is to take your screwdriver and remove all 13 screws keeping the back panel in place. After every screw is removed and placed in or on something where you won't lose it, carefully life up the back panel off of the laptop.
    • Gently brush each blade of the fans with your toothbrush or soft cloth. If your cleaning tool starts to get too dirty, wipe off any dust with a dry cloth or grab a new, clean cloth or toothbrush.
    • Carefully place the back panel onto the laptop and gently press down along the edges until you hear a click. One the panel is secure and not moving around, put every screw back into place and screw them in.
    • Finally, after the laptop is put back together, turn it on and check if it is still functional.
Tudor L
Membro da: 05/09/24
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 60
Tutti i Tempi: 425
