Salta al contenuto principale
MSI GT75VR 7RF Titan Pro RAM Card Replacement
Cosa ti serve
  1. MSI GT75VR 7RF Titan Pro RAM Card Replacement, RAM Card: passo 1, immagine 1 di 1
    • Unscrew each of the four screws using the Phillips #0 head on the back of the laptop case. The screws are 0.5 inches in length.
  2. MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 2, immagine 1 di 2 MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 2, immagine 2 di 2
    • Pop the back cover off of the laptop using the black nylon spudger.
  3. MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 3, immagine 1 di 1
    • Disconnect the battery cable.
  4. MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 4, immagine 1 di 2 MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 4, immagine 2 di 2
    • Pry the battery pack up with the black nylon spudger.
  5. MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 5, immagine 1 di 1
    • Pop the metal tabs on each side of the RAM using the black nylon spudger.
  6. MSI GT75VR 7RF Titan Pro RAM Card Replacement: passo 6, immagine 1 di 1
    • Lift and remove RAM card by hand. Replace each RAM card and test them individually. If your computer encounters a RAM error with only one card inserted, you can confirm that card is corrupted.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 742
