Salta al contenuto principale
MSI GT62VR 6RD Dominator Speaker Replacement
Cosa ti serve
  1. MSI GT62VR 6RD Dominator Speaker Replacement, Battery: passo 1, immagine 1 di 2 MSI GT62VR 6RD Dominator Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the 6 screws on the bottom plate of the laptop using a Phillips driver.
  2. MSI GT62VR 6RD Dominator Speaker Replacement: passo 2, immagine 1 di 2 MSI GT62VR 6RD Dominator Speaker Replacement: passo 2, immagine 2 di 2
    • Insert the plastic opening tool into the back plate of the laptop and lightly pry it up.
    • The laptop cover will break if it is being handled roughly.
    • Slide the plastic opening tool around the laptop's edge gently, slowly popping off the clips securing it into the laptop.
    • Remove the back plate.
  3. MSI GT62VR 6RD Dominator Speaker Replacement: passo 3, immagine 1 di 3 MSI GT62VR 6RD Dominator Speaker Replacement: passo 3, immagine 2 di 3 MSI GT62VR 6RD Dominator Speaker Replacement: passo 3, immagine 3 di 3
    • Locate the battery.
    • The wires are located at the back end of the battery and covered in tape.
    • Remove the tape covering the battery connector.
    • Place your hands at the corners of the wires.
    • Pull upward from the back end of the battery where the wires are located.
    • Remove the battery.
  4. MSI GT62VR 6RD Dominator Speaker Replacement, Hard Drive: passo 4, immagine 1 di 2 MSI GT62VR 6RD Dominator Speaker Replacement, Hard Drive: passo 4, immagine 2 di 2
    • Remove the six screws on the back plate of the laptop using a JIS #0 screwdriver.
  5. MSI GT62VR 6RD Dominator Speaker Replacement: passo 5, immagine 1 di 3 MSI GT62VR 6RD Dominator Speaker Replacement: passo 5, immagine 2 di 3 MSI GT62VR 6RD Dominator Speaker Replacement: passo 5, immagine 3 di 3
    • Insert a plastic opening tool into the seam of the back cover
    • Pry the cover up until clips release.
    • Slide the plastic opening tool around the laptop until cover is fully removed.
  6. MSI GT62VR 6RD Dominator Speaker Replacement: passo 6, immagine 1 di 2 MSI GT62VR 6RD Dominator Speaker Replacement: passo 6, immagine 2 di 2
    • Remove the two screws securing the hard drive to the laptop.
    • Lightly lift the hard drive up by grasping the silver bracket that secures it to the laptop.
    • Wiggle it backwards slowly until it is unplugged.
    • Slide out from under the cover towards the battery.
  7. MSI GT62VR 6RD Dominator Speaker Replacement, Speaker: passo 7, immagine 1 di 2 MSI GT62VR 6RD Dominator Speaker Replacement, Speaker: passo 7, immagine 2 di 2
    • Insert the plastic opening tool into the side of the laptop above the fan, and lightly pry it up.
    • The laptop will break if it is being handle roughly.
    • Slide the plastic opening tool around the laptop's edge gently, while slowly popping off the clips securing it into the laptop.
  8. MSI GT62VR 6RD Dominator Speaker Replacement: passo 8, immagine 1 di 2 MSI GT62VR 6RD Dominator Speaker Replacement: passo 8, immagine 2 di 2
    • Slowly pop off the clips securing the speaker to the laptop side frame.
  9. MSI GT62VR 6RD Dominator Speaker Replacement: passo 9, immagine 1 di 3 MSI GT62VR 6RD Dominator Speaker Replacement: passo 9, immagine 2 di 3 MSI GT62VR 6RD Dominator Speaker Replacement: passo 9, immagine 3 di 3
    • Locate the speaker wires.
    • The speaker wires are attached to the speaker. By running your hand across the speaker wires, you can find its location on the motherboard.
    • Pull upward from the motherboard where the wires are located.
Conclusione
Un commento
this is only for the sub, the other speaker is a nightmare to replace
Jeffrey Binns - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 489
