Salta al contenuto principale
MSI GT62VR 6RD Dominator Hard Drive Replacement
Cosa ti serve
  1. MSI GT62VR 6RD Dominator Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 MSI GT62VR 6RD Dominator Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Remove the six screws on the back plate of the laptop using a JIS #0 screwdriver.
  2. MSI GT62VR 6RD Dominator Hard Drive Replacement: passo 2, immagine 1 di 3 MSI GT62VR 6RD Dominator Hard Drive Replacement: passo 2, immagine 2 di 3 MSI GT62VR 6RD Dominator Hard Drive Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool into the seam of the back cover
    • Pry the cover up until clips release.
    • Slide the plastic opening tool around the laptop until cover is fully removed.
  3. MSI GT62VR 6RD Dominator Hard Drive Replacement: passo 3, immagine 1 di 2 MSI GT62VR 6RD Dominator Hard Drive Replacement: passo 3, immagine 2 di 2
    • Remove the two screws securing the hard drive to the laptop.
    • Lightly lift the hard drive up by grasping the silver bracket that secures it to the laptop.
    • Wiggle it backwards slowly until it is unplugged.
    • Slide out from under the cover towards the battery.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 738
