Salta al contenuto principale
MSI GT62VR 6RD Dominator Cooling Fan Replacement
Cosa ti serve
  1. MSI GT62VR 6RD Dominator Cooling Fan Replacement, Cooling Fan: passo 1, immagine 1 di 2 MSI GT62VR 6RD Dominator Cooling Fan Replacement, Cooling Fan: passo 1, immagine 2 di 2
    • Remove the six 1.2mm screws on the bottom plate of the laptop using a JIS #0 screwdriver.
  2. MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 2, immagine 1 di 3 MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 2, immagine 2 di 3 MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 2, immagine 3 di 3
    • Insert the plastic opening tools into the seam on the back plate of the laptop.
    • A popping sound may come from your device while you remove the backplate.
    • Pry the back plate up.
    • Slide the plastic opening tool around the laptop's edge slowly until the backplate is completely removed.
  3. MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 3, immagine 1 di 2 MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 3, immagine 2 di 2
    • Remove the three 2.0mm screws using the JIS #0 screwdriver.
  4. MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 4, immagine 1 di 2 MSI GT62VR 6RD Dominator Cooling Fan Replacement: passo 4, immagine 2 di 2
    • The white plastic clip secures the fan wires to the laptop.
    • Unplug the white clip by grasping it and wiggling it back and forth .
    • Do not pull the clip out by the wires themselves.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,554
