Salta al contenuto principale
MSI GT62VR 6RD Dominator Battery Replacement
Cosa ti serve
  1. MSI GT62VR 6RD Dominator Battery Replacement, Battery: passo 1, immagine 1 di 2 MSI GT62VR 6RD Dominator Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the 6 screws on the bottom plate of the laptop using a Phillips driver.
  2. MSI GT62VR 6RD Dominator Battery Replacement: passo 2, immagine 1 di 2 MSI GT62VR 6RD Dominator Battery Replacement: passo 2, immagine 2 di 2
    • Insert the plastic opening tool into the back plate of the laptop and lightly pry it up.
    • The laptop cover will break if it is being handled roughly.
    • Slide the plastic opening tool around the laptop's edge gently, slowly popping off the clips securing it into the laptop.
    • Remove the back plate.
  3. MSI GT62VR 6RD Dominator Battery Replacement: passo 3, immagine 1 di 3 MSI GT62VR 6RD Dominator Battery Replacement: passo 3, immagine 2 di 3 MSI GT62VR 6RD Dominator Battery Replacement: passo 3, immagine 3 di 3
    • Locate the battery.
    • The wires are located at the back end of the battery and covered in tape.
    • Remove the tape covering the battery connector.
    • Place your hands at the corners of the wires.
    • Pull upward from the back end of the battery where the wires are located.
    • Remove the battery.
Conclusione
Rebekah Johnson
Membro da: 09/18/18
147 Reputazione
1 Guida realizzata
1Commento della guida
Can i use it using chargine cable even if i remove rhe battery?
Tabs XXIV - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 37
Tutti i Tempi: 2,091
