Salta al contenuto principale
MSI GS70 Battery Replacement
Cosa ti serve
  1. MSI GS70 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure that the laptop is turned off before starting.
    • Place laptop with the bottom plate facing up.
  2. MSI GS70 Battery Replacement: passo 2, immagine 1 di 1
    • Remove all screws using the JIS #1 screwdriver.
  3. MSI GS70 Battery Replacement: passo 3, immagine 1 di 1
    • Remove the back plate.
    • Locate the battery.
  4. MSI GS70 Battery Replacement: passo 4, immagine 1 di 1
    • Locate the foil connector above the battery.
  5. MSI GS70 Battery Replacement: passo 5, immagine 1 di 1
    • Flip up both black clips with your spudger.
  6. MSI GS70 Battery Replacement: passo 6, immagine 1 di 1
    • Remove the foil connector by pulling on the blue tabs.
  7. MSI GS70 Battery Replacement: passo 7, immagine 1 di 1
    • After the foil connector is removed you will see an 8 pin connector.
    • Disconnect the 8 Pin connector.
  8. MSI GS70 Battery Replacement: passo 8, immagine 1 di 1
    • Lift the battery and remove.
Conclusione
Altre 11 persone hanno completato questa guida.
5Commenti sulla guida
Perfect guide
storolle - Replica
Anyone know what the foil connector is? Mine is broken, and needs to be replaced.
Jonathan Hawkes - Replica
Which battery model should I buy?
slackware2007 - Replica
BTY-L76 seems like a good fit
uchadhana (다나) -
I want to replace the battery and lcd cover of the msi gs72 6qe stealth pro. Are the msi gs70 parts compatible with the msi gs72? because I have difficulty finding msi gs72 parts in my country (indonesia)
uchadhana (다나) - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 42
Tutti i Tempi: 9,620
