Salta al contenuto principale
MSI GS66 Stealth 11UE-007 RAM Replacement
Cosa ti serve
  1. MSI GS66 Stealth 11UE-007 RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure to unplug device from any outlet.
  2. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 2, immagine 1 di 1
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
  3. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 3, immagine 1 di 1
    • Remove eight 10 mm Phillips #1 screws.
  4. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 4, immagine 1 di 1
    • Remove one 7 mm Philips #1 screw from the center bottom of backplate.
  5. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 5, immagine 1 di 3 MSI GS66 Stealth 11UE-007 RAM Replacement: passo 5, immagine 2 di 3 MSI GS66 Stealth 11UE-007 RAM Replacement: passo 5, immagine 3 di 3
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate is from the body of the laptop.
  6. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 6, immagine 1 di 2 MSI GS66 Stealth 11UE-007 RAM Replacement: passo 6, immagine 2 di 2
    • Lift back black plastic.
  7. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 7, immagine 1 di 2 MSI GS66 Stealth 11UE-007 RAM Replacement: passo 7, immagine 2 di 2
    • Place both thumbs on metal tabs and apply pressure in a widening motion until RAM lifts.
  8. MSI GS66 Stealth 11UE-007 RAM Replacement: passo 8, immagine 1 di 1
    • Pull RAM straight out from the connector at the angle it lifted at.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 334
