Salta al contenuto principale
MSI GS66 Stealth 11UE-007 NVMe SSD Replacement
Cosa ti serve
  1. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement, NVMe SSD: passo 1, immagine 1 di 1
    • Orient your laptop so that the bottom is facing up and the hinge is away from yourself.
    • Make sure device is not connected to any outlet.
  2. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: passo 2, immagine 1 di 1
    • Identify the nine screws around the perimeter. One screw will be under the factory seal sticker.
  3. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: passo 3, immagine 1 di 1
    • Remove eight 10 mm Phillips #1 screws.
  4. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: passo 4, immagine 1 di 1
    • Remove one 7 mm Philips #1 screw from the center bottom of backplate.
  5. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: passo 5, immagine 1 di 3 MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: passo 5, immagine 2 di 3 MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: passo 5, immagine 3 di 3
    • Use the tip of the blue plastic opening tool to slip between the backplate and the body of the laptop at the hinge side.
    • Wiggle the blue plastic opening tool as you slide it around the perimeter of the backplate to separate it from the body of the laptop.
  6. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: passo 6, immagine 1 di 1
    • Lift back black plastic.
  7. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: passo 7, immagine 1 di 1
    • Remove one 4 mm Phillips #1 screw.
  8. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: passo 8, immagine 1 di 2 MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: passo 8, immagine 2 di 2
    • Lift the drive up to forty-five degrees and pull at that forty-five degree angle away from the connector.
  9. MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: passo 9, immagine 1 di 2 MSI GS66 Stealth 11UE-007 NVMe SSD Replacement: passo 9, immagine 2 di 2
    • Remove the thermal pad.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 23
Tutti i Tempi: 169
