Introduzione
A properly functioning hard drive is essential for a gaming computer. A faulty hard drive can slow down the computer and cause it to freeze, as well as corrupt data. If your hard drive has gone bad, here is how you can replace it.
Cosa ti serve
Use the spudger to separate the back plate from the rest of the computer with the screen up like in the picture.
Once the back plate is loose, close the screen for an easier time properly removing it.
Using a Phillips Head #1 screwdriver, unscrew the 15 screws on the bottom of the device
After all the screws are unscrewed, remove the bottom plate. If this is the first time that you are removing this back cover, the last screw is hidden under the "factory seal" label. You will need to break that label to reach that screw.
Altre 4 persone hanno completato questa guida.
3 Commenti
Could you please give more details on how to remove the backplate in step 1? It is the most fragile part in the whole laptop and the first one to get damaged/broken as well. Some more pictures of the process would be great.
I agree with you… i would like some more pictures on how to put the new SSD or HDD in and put everything back to
I just did the first step of loosening screen with spudger - not sure if needed or not, but I did it and some metal things popped. Then unscrewed all the screws and left them in place and propped just the back of the cover partially open. Hard drive then just came out, no need to touch the battery. Switched the ribbon connector to 1 TB SSD, screwed the cover back on and everything worked. Now cloning old drive with Macrium Reflect Free Edition. Love the tools in replacement kit for those who don’t already have a USB-3 enclosure/a full set of repair essentials. Also things organized in a box called iFixit are less likely to lose peaces or be misplaced.
