Salta al contenuto principale
MSI GS63VR 6RF Stealth Pro WiFi Card Replacement
Cosa ti serve
  1. MSI GS63VR 6RF Stealth Pro WiFi Card Replacement, Wi-Fi Card: passo 1, immagine 1 di 3 MSI GS63VR 6RF Stealth Pro WiFi Card Replacement, Wi-Fi Card: passo 1, immagine 2 di 3 MSI GS63VR 6RF Stealth Pro WiFi Card Replacement, Wi-Fi Card: passo 1, immagine 3 di 3
    • First, turn off the laptop and make sure it is unplugged from power to avoid injury.
    • Unscrew the 15 screws on the bottom panel of the computer using a Phillips #00 screwdriver.
    • Lift open the back cover with a plastic spudger.
    • Gently lift the back cover away from computer. Make sure nothing is attached.
    • Unplug the battery cable from the motherboard to prevent a ground fault.
    • Too much pressure from the spudger can break the clips that secure the back panel, but some flex is not dangerous.
  2. MSI GS63VR 6RF Stealth Pro WiFi Card Replacement: passo 2, immagine 1 di 2 MSI GS63VR 6RF Stealth Pro WiFi Card Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Unscrew the single screw from the Wifi card using a Phillips #00 screwdriver.
    • Apply upward pressure on the cables using a plastic tweezer.
    • Using the plastic tweezers, carefully grab and gently wiggle the Wifi card out of its socket.
    • Gently pull the card upward from the slot.
    • The Wi-Fi cables can be easily damaged when removing or replacing the connectors. Please take extra care when performing these tasks
Linea Traguardo
3Commenti sulla guida
Is this a msata card or a m.2 card?
keith dragon - Replica
Hi, do you know where I can find some new wifi cables? I broke mine (with my WiFi card) and looking to repair it
Best regards
Bastien Allaoui - Replica
Hi there , the wifi cable (aux) its not connecting to the card , probaly I have bent it , what problem does it cause because right now I still can use the wifi, and most important thing , where can I buy it and how can change it ? Thanks
Adriano - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 29
Tutti i Tempi: 4,379
