Salta al contenuto principale
MSI GS63VR 6RF Stealth Pro Hard Drive Replacement
Cosa ti serve
  1. MSI GS63VR 6RF Stealth Pro Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 3 MSI GS63VR 6RF Stealth Pro Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 3 MSI GS63VR 6RF Stealth Pro Hard Drive Replacement, Hard Drive: passo 1, immagine 3 di 3
    • Turn off the laptop before proceeding.
    • Unscrew the 15 screws on the bottom panel using a Phillips #00 screwdriver.
    • Pry open the back cover with a plastic prying tool.
    • Unplug the battery cable from the motherboard to prevent a ground fault. Either use your hand or a pair of tweezers to unplug the battery cable.
    • Too much pressure from the spudger can break the clips that secure the back panel, but some flex is not dangerous.
  2. MSI GS63VR 6RF Stealth Pro Hard Drive Replacement: passo 2, immagine 1 di 3 MSI GS63VR 6RF Stealth Pro Hard Drive Replacement: passo 2, immagine 2 di 3 MSI GS63VR 6RF Stealth Pro Hard Drive Replacement: passo 2, immagine 3 di 3
    • Disconnect the SATA cables from the motherboard using a plastic spudger.
    • Gently pull out the SATA cables out of the ports.
    • Grab the auburn color cable and lift up the hard drive. Slide out the hard drive while holding onto the cable.
    • Cables are fragile. Do not apply excessive force.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,115
