Salta al contenuto principale
MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement
Cosa ti serve
  1. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place this device back panel facing up.
  2. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement: passo 2, immagine 1 di 1
    • Using the screwdriver, unscrew the highlighted 1.2mm Phillips head #0 screws which secure the back panel into place.
  3. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement: passo 3, immagine 1 di 2 MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement: passo 3, immagine 2 di 2
    • Using the plastic opening tools, separate the back panel from the rest of the device.
    • Do this by firmly pressing the head of the tool into the space between the back panel, and the rest of the device.
  4. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement, Wi-Fi Card: passo 4, immagine 1 di 1
    • Use the screwdriver to unscrew the 0.5mm Phillips #0 screw holding the Wi-Fi card in place.
  5. MSI GS60 Ghost Pro 4K Gold Edition Wi-Fi Card Replacement: passo 5, immagine 1 di 1
    • Take out the Wi-Fi card.
    • Replace the faulty Wi-Fi card with a new Wi-Fi card.
Conclusione
Jordan Williams
Membro da: 10/19/17
201 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 659
