Salta al contenuto principale
MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement
Cosa ti serve
  1. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Remove the eleven 5mm screws with a Phillips #1 screwdriver.
    • Remove the four 2.5mm screws with a Phillips #1 screwdriver.
  2. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the bottom plate from the laptop. Using a prying tool to slide between the bottom plate and chassis will result in easier removal.
  3. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 3, immagine 1 di 1
    • Remove the four 2.5mm screws using a Phillips #1 bit.
  4. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 4, immagine 1 di 1
    • Carefully pry the screen assembly from the chassis on both sides. Use caution as the cable to the screen is located on the right bracket.
  5. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 5, immagine 1 di 2 MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 5, immagine 2 di 2
    • Lay the components out as shown.
    • The rightmost of the two cable connections is located under sticky tape. Remove the tape to access it and unseat from the connection.
    • The other connection is removed by gently pulling up on the black grip tape.
  6. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 6, immagine 1 di 2 MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 6, immagine 2 di 2
    • Gently feed both connections under the red, white, and yellow cables from the fan.
    • Note that both cables will meet and form a singular cable.
  7. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 7, immagine 1 di 2 MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 7, immagine 2 di 2
    • Gently lift up on the back of the fan and remove the routed cable.
  8. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 8, immagine 1 di 3 MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 8, immagine 2 di 3 MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 8, immagine 3 di 3
    • Using a prying tool, find the seam where the two pieces of screen meet and begin separating them.
    • Use caution, as there is glue and snapping clips holding them together.
    • Work around the perimeter, separating the pieces with the prying tool as you go.
  9. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 9, immagine 1 di 1
    • Locate the metal bracket the cable is woven through.
    • Unweave the cable from the bracket. This will give you extra length to work with the screen.
  10. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 10, immagine 1 di 1
    • Remove two 2.5mm screws with a Phillips #1 screwdriver.
  11. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 11, immagine 1 di 2 MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 11, immagine 2 di 2
    • Remove the screen.
    • Gently remove the yellow tape and then remove the connector.
  12. MSI GS60 6QE GHOST PRO 4K LCD Screen Replacement: passo 12, immagine 1 di 1
    • The defective screen is now completely removed and ready to be replaced.
Conclusione
Altre 2 persone hanno completato questa guida.
Coty Mast
Membro da: 11/10/18
259 Reputazione
1 Guida realizzata
IUPUI, Team S1-G1, Wilson Fall 2018 Membro di IUPUI, Team S1-G1, Wilson Fall 2018
IUPUI-WILSON-F18S1G1
4 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,974
