Salta al contenuto principale
MSI GP62MVR 6RF Leopard Pro Speakers Replacement
Cosa ti serve
  1. MSI GP62MVR 6RF Leopard Pro Speakers Replacement, Bottom Cover: passo 1, immagine 1 di 2 MSI GP62MVR 6RF Leopard Pro Speakers Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: passo 2, immagine 1 di 2 MSI GP62MVR 6RF Leopard Pro Speakers Replacement: passo 2, immagine 2 di 2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: passo 3, immagine 1 di 1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Speakers Replacement, Speakers: passo 4, immagine 1 di 1
    • Reorient the computer, if necessary, with a 180 degree turn so that the speakers face you.
  5. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: passo 5, immagine 1 di 1
    • On the front panel near the right speaker, there is a connection from the motherboard to the speakers.
    • Detach the white and black wiring from the clip.
  6. MSI GP62MVR 6RF Leopard Pro Speakers Replacement: passo 6, immagine 1 di 1
    • Peel back the electrical tape holding the speaker wire in place.
    • Remove the speakers from the front panel, pulling upward.
    • Note that the screws holding the two speakers down were already removed during the bottom cover removal.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 347
