Salta al contenuto principale
MSI GP62MVR 6RF Leopard Pro Fans Replacement
Cosa ti serve
  1. MSI GP62MVR 6RF Leopard Pro Fans Replacement, Bottom Cover: passo 1, immagine 1 di 2 MSI GP62MVR 6RF Leopard Pro Fans Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 2, immagine 1 di 2 MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 2, immagine 2 di 2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 3, immagine 1 di 1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Fans Replacement, Fans: passo 4, immagine 1 di 2 MSI GP62MVR 6RF Leopard Pro Fans Replacement, Fans: passo 4, immagine 2 di 2
    • Remove the eight 4.5 mm screws that hold the heat sink to the motherboard with a Phillips #0 screwdriver.
    • Remove the four 4.5 mm screws holding the fan in place also using a Phillips #0 screwdriver.
    • Watch for the screw hidden under the wires highlighted in the second picture.
  5. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 5, immagine 1 di 2 MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 5, immagine 2 di 2
    • Disconnect both power cables for the fans.
    • Make sure to pinch the power cables. It may require a bit of force.
  6. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 6, immagine 1 di 3 MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 6, immagine 2 di 3 MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 6, immagine 3 di 3
    • Using the Jimmy tool, remove the adhesive pads securing the fans to the board.
  7. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 7, immagine 1 di 1
    • Remove the black adhesive.
  8. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 8, immagine 1 di 1
    • Separate the heat sink from the tab on the side holding the fan in place.
  9. MSI GP62MVR 6RF Leopard Pro Fans Replacement: passo 9, immagine 1 di 1
    • Remove the three 3.5 mm screws on each fan holding the fan to the heat sink using a Phillips #0 screwdriver.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,195
