Salta al contenuto principale
MSI GP62MVR 6RF Leopard Pro Battery Replacement
Cosa ti serve
  1. MSI GP62MVR 6RF Leopard Pro Battery Replacement, Bottom Cover: passo 1, immagine 1 di 2 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Bottom Cover: passo 1, immagine 2 di 2
    • Place the laptop upside down.
    • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
  2. MSI GP62MVR 6RF Leopard Pro Battery Replacement: passo 2, immagine 1 di 2 MSI GP62MVR 6RF Leopard Pro Battery Replacement: passo 2, immagine 2 di 2
    • Use the Jimmy tool to evenly pry loose the bottom cover.
    • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
  3. MSI GP62MVR 6RF Leopard Pro Battery Replacement: passo 3, immagine 1 di 1
    • Remove the back cover.
    • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
  4. MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: passo 4, immagine 1 di 3 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: passo 4, immagine 2 di 3 MSI GP62MVR 6RF Leopard Pro Battery Replacement, Battery: passo 4, immagine 3 di 3
    • Using a Phillips #0 Screwdriver, remove the single 5.5 mm screw fastening the battery to the body of the computer.
    • Remove the battery from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,199
