Salta al contenuto principale
MSI GP60 2PE Leopard Wireless Card Replacement
Cosa ti serve
  1. MSI GP60 2PE Leopard Wireless Card Replacement, Battery: passo 1, immagine 1 di 1
    • Flip MSI GP60 2PE Leopard, so that the back is facing up.
  2. MSI GP60 2PE Leopard Wireless Card Replacement: passo 2, immagine 1 di 1
    • Find the unlock tab located on the upper right side of the device, then slide it to the right.
  3. MSI GP60 2PE Leopard Wireless Card Replacement: passo 3, immagine 1 di 3 MSI GP60 2PE Leopard Wireless Card Replacement: passo 3, immagine 2 di 3 MSI GP60 2PE Leopard Wireless Card Replacement: passo 3, immagine 3 di 3
    • Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
  4. MSI GP60 2PE Leopard Wireless Card Replacement: passo 4, immagine 1 di 3 MSI GP60 2PE Leopard Wireless Card Replacement: passo 4, immagine 2 di 3 MSI GP60 2PE Leopard Wireless Card Replacement: passo 4, immagine 3 di 3
    • While holding the release tab, remove the battery slowly.
  5. MSI GP60 2PE Leopard Wireless Card Replacement, Back Panel: passo 5, immagine 1 di 1
    • Flip the device over so the back is facing up.
  6. MSI GP60 2PE Leopard Wireless Card Replacement: passo 6, immagine 1 di 2 MSI GP60 2PE Leopard Wireless Card Replacement: passo 6, immagine 2 di 2
    • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
    • There is a screw located under the battery; lift the battery up to access it.
  7. MSI GP60 2PE Leopard Wireless Card Replacement: passo 7, immagine 1 di 2 MSI GP60 2PE Leopard Wireless Card Replacement: passo 7, immagine 2 di 2
    • Once all four screws are removed, lift the back off.
  8. MSI GP60 2PE Leopard Wireless Card Replacement, Wireless Card: passo 8, immagine 1 di 1
    • Locate the wireless card.
  9. MSI GP60 2PE Leopard Wireless Card Replacement: passo 9, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the one 2 mm screw that is holding the wireless card in place.
  10. MSI GP60 2PE Leopard Wireless Card Replacement: passo 10, immagine 1 di 1
    • Carefully remove the wireless card.
    • Pay close attention to the two wires attached to wireless card.
  11. MSI GP60 2PE Leopard Wireless Card Replacement: passo 11, immagine 1 di 2 MSI GP60 2PE Leopard Wireless Card Replacement: passo 11, immagine 2 di 2
    • Remove the wires connecting to the wireless card by pinching around the base where they connect, then carefully disconnect them.
    • The wires should come off fairly easily.
    • Avoid yanking or pulling too hard. This can result in the wires breaking.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,350
