Salta al contenuto principale
MSI GE72 6QF Apache Pro Optical Drive Replacement
Cosa ti serve
  1. MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: passo 1, immagine 1 di 2 MSI GE72 6QF Apache Pro Optical Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 2, immagine 1 di 1
    • Slide the optical drive out of the laptop.
    Good day sir pls am urgently look for the complete cd rom for this laptop msi 1791. Please if u can get some for me text me on 7186034112
    rauffsulemane - Replica
    Or send me and email rauff191@gmail.com
  3. MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 3, immagine 1 di 1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 4, immagine 1 di 2 MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 4, immagine 2 di 2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 5, immagine 1 di 2 MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 5, immagine 2 di 2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 6, immagine 1 di 2 MSI GE72 6QF Apache Pro Optical Drive Replacement: passo 6, immagine 2 di 2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: passo 7, immagine 1 di 3 MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: passo 7, immagine 2 di 3 MSI GE72 6QF Apache Pro Optical Drive Replacement, Optical Drive: passo 7, immagine 3 di 3
    • Carefully slide the Optical Drive off of the SATA connector.
    • The red marker shows the location for where the retaining screw comes through the back panel to hold the Optical Drive.
Conclusione
2 Commenti
Why do you have to remove the battery first?
Kevin - Replica
So you don’t have power running through it while working on it.
croberts1290 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,437
