Salta al contenuto principale
MSI GE72 6QF Apache Pro Hard Drive Replacement
Cosa ti serve
  1. MSI GE72 6QF Apache Pro Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 MSI GE72 6QF Apache Pro Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Hard Drive Replacement: passo 2, immagine 1 di 1
    • Slide the optical drive out of the laptop.
    Good day sir pls am urgently look for the complete cd rom for this laptop msi 1791. Please if u can get some for me text me on 7186034112
    rauffsulemane - Replica
    Or send me and email rauff191@gmail.com
  3. MSI GE72 6QF Apache Pro Hard Drive Replacement: passo 3, immagine 1 di 1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Hard Drive Replacement: passo 4, immagine 1 di 2 MSI GE72 6QF Apache Pro Hard Drive Replacement: passo 4, immagine 2 di 2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Hard Drive Replacement: passo 5, immagine 1 di 2 MSI GE72 6QF Apache Pro Hard Drive Replacement: passo 5, immagine 2 di 2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Hard Drive Replacement: passo 6, immagine 1 di 2 MSI GE72 6QF Apache Pro Hard Drive Replacement: passo 6, immagine 2 di 2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Hard Drive Replacement, Hard Drive: passo 7, immagine 1 di 2 MSI GE72 6QF Apache Pro Hard Drive Replacement, Hard Drive: passo 7, immagine 2 di 2
    • Remove the two 5.5mm screws with the Phillips #1 screwdriver.
  8. MSI GE72 6QF Apache Pro Hard Drive Replacement: passo 8, immagine 1 di 2 MSI GE72 6QF Apache Pro Hard Drive Replacement: passo 8, immagine 2 di 2
    • Gently pull out the hard drive by wiggling it from right to left with your hands until it is removed.
Conclusione
Altre 6 persone hanno completato questa guida.
Tanmay Kumar
Membro da: 04/17/17
458 Reputazione
4 Guide realizzate
Cal Poly, Team S14-G4, Banghart Spring 2017 Membro di Cal Poly, Team S14-G4, Banghart Spring 2017
CPSU-BANGHART-S17S14G4
4 Membri
8 Guide realizzate
Un commento
I have just bought an MSI GP72VR Laptop and I screwed up and got the model with only one drive, an SSD. It nagged at me that I didn't get the one with 2 drives. Well I happen to build my own desktops and had a spare 500GB Mushkin SSD hanging around and decided, what the heck. I came here and couldn't find the exact model but this is identical for what I want. I have never seen an access like this where you have to remove 19 screws. So I am very happy that this is on iFixit. I removed the screws and couldn't get the bottom removed as shown, I had to go to the other side and then it came off fairly easily. I used a butter knife for the initial pry and that worked well. They had sent the disk holder with the computer so I had no problem installing and I just set it up in Disk Manager. Tanmay, thank you very much for the assist, it is appreciated.
adard745 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 23
Tutti i Tempi: 7,764
