Salta al contenuto principale
MSI GE72 6QF Apache Pro Fan Replacement
Cosa ti serve
  1. MSI GE72 6QF Apache Pro Fan Replacement, Battery: passo 1, immagine 1 di 2 MSI GE72 6QF Apache Pro Fan Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure the laptop is off and unplugged (not charging).
    • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
  2. MSI GE72 6QF Apache Pro Fan Replacement: passo 2, immagine 1 di 1
    • Slide the optical drive out of the laptop.
    Good day sir pls am urgently look for the complete cd rom for this laptop msi 1791. Please if u can get some for me text me on 7186034112
    rauffsulemane - Replica
    Or send me and email rauff191@gmail.com
  3. MSI GE72 6QF Apache Pro Fan Replacement: passo 3, immagine 1 di 1
    • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
  4. MSI GE72 6QF Apache Pro Fan Replacement: passo 4, immagine 1 di 2 MSI GE72 6QF Apache Pro Fan Replacement: passo 4, immagine 2 di 2
    • Using your fingers, gently loosen the edges of all four sides of the back cover.
    • Gently pull off the back cover.
  5. MSI GE72 6QF Apache Pro Fan Replacement: passo 5, immagine 1 di 2 MSI GE72 6QF Apache Pro Fan Replacement: passo 5, immagine 2 di 2
    • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
  6. MSI GE72 6QF Apache Pro Fan Replacement: passo 6, immagine 1 di 2 MSI GE72 6QF Apache Pro Fan Replacement: passo 6, immagine 2 di 2
    • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
  7. MSI GE72 6QF Apache Pro Fan Replacement, Fan: passo 7, immagine 1 di 3 MSI GE72 6QF Apache Pro Fan Replacement, Fan: passo 7, immagine 2 di 3 MSI GE72 6QF Apache Pro Fan Replacement, Fan: passo 7, immagine 3 di 3
    • If you are replacing only the keyboard, you can skip to step 18, and then skip the WiFi adapter removal step. The CPU fan, m.2 SSD, RAM and WiFi adapter (marked in green) will all come off with the main board, giving you access to the keyboard.
    • Use a Phillips #1 screwdriver to remove the ten 5.5mm screws.
    • Remove the last two 5.5mm Phillips #1 screws, and remove the washers around them.
  8. MSI GE72 6QF Apache Pro Fan Replacement: passo 8, immagine 1 di 3 MSI GE72 6QF Apache Pro Fan Replacement: passo 8, immagine 2 di 3 MSI GE72 6QF Apache Pro Fan Replacement: passo 8, immagine 3 di 3
    • Unplug both of the fan power cords from the laptop using a spudger.
  9. MSI GE72 6QF Apache Pro Fan Replacement: passo 9, immagine 1 di 2 MSI GE72 6QF Apache Pro Fan Replacement: passo 9, immagine 2 di 2
    • Continue to use the spudger to carefully separate the wires of the power cord from the laptop.
  10. MSI GE72 6QF Apache Pro Fan Replacement: passo 10, immagine 1 di 2 MSI GE72 6QF Apache Pro Fan Replacement: passo 10, immagine 2 di 2
    • Fully remove the fans from the rest of the laptop.
    what is the thing that the fans are held in called like that big metal thing i need to get that replaced i think and i dont know how ot search for it
    BW NINOQUIMPS - Replica
  11. MSI GE72 6QF Apache Pro Fan Replacement: passo 11, immagine 1 di 3 MSI GE72 6QF Apache Pro Fan Replacement: passo 11, immagine 2 di 3 MSI GE72 6QF Apache Pro Fan Replacement: passo 11, immagine 3 di 3
    • Using a Phillips #00 screwdriver, remove the six 5mm screws.
    • Separate the fans from the silver fan covers.
    Should be mentioned that doing this will ALSO require repasting the CPU/GPU!!!
    Not doing this step will result in improper cooling more than likely. - CRITICAL STEP
    Mame A - Replica
    Thanks for the heads up
    Daniel Martin -
Conclusione
Altre 20 persone hanno completato questa guida.
Tanmay Kumar
Membro da: 04/17/17
458 Reputazione
4 Guide realizzate
Cal Poly, Team S14-G4, Banghart Spring 2017 Membro di Cal Poly, Team S14-G4, Banghart Spring 2017
CPSU-BANGHART-S17S14G4
4 Membri
8 Guide realizzate
9 Commenti
I can't get the back case off the last bit of it is held on pretty tight. All the screws are out so how do I loosen it?
Aaron Carlston - Replica
Where can I buy new fans?
Aschwin Versteegden - Replica
Where do you buy the replacement fans
customgirl - Replica
I need a link to buy the actual fan itself if you wouldn’t mind I’d greatly appreciate it
dylan davis - Replica
EDIT: The only place I could actually find the fans were on walmart so Ill post the link here -> https://www.walmart.com/search/?query=ms... (I personally bought the blue one that was first I should get it by next friday and Ill try and remember to post if it works or not)
dylan davis -
You need both fans cpu and gpu here is a link https://www.amazon.com/Cooling-Ge72-Ge62...
Paul - Replica
Hello, nice work. I have problem with my msi ge72 6qd and i wander if is possible to find better fan from stock. Any ideas? Thank you again nice work and you are very understandable.
dimos kiriazis - Replica
If you are using this guide, don't forget to reapply thermal paste after disassembly.
Kasparas - Replica
Great article! I didn't even have any screws left over when I finished! :)
Google Sux - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 74
Tutti i Tempi: 25,232
