Salta al contenuto principale
MSI GE62 Apache Pro 004 Web Camera Replacement
Cosa ti serve
  1. MSI GE62 Apache Pro 004 Web Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 2, immagine 1 di 2 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 2, immagine 2 di 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 3, immagine 1 di 3 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 3, immagine 2 di 3 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 3, immagine 3 di 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Web Camera Replacement, Web Camera: passo 4, immagine 1 di 1
    • Flip over the laptop and open it.
  5. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 5, immagine 1 di 3 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 5, immagine 2 di 3 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 5, immagine 3 di 3
    • Slide a metal opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
  6. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 6, immagine 1 di 2 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 6, immagine 2 di 2
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
  7. MSI GE62 Apache Pro 004 Web Camera Replacement: passo 7, immagine 1 di 2 MSI GE62 Apache Pro 004 Web Camera Replacement: passo 7, immagine 2 di 2
    • Locate the WebCam on the middle of the device.
    • Slide a metal opener tool to remove the Webcam
Conclusione
USF Tampa, Team S15-G5, Boczar Spring 2018 Membro di USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 821
